Chuck Chandler
I bought a $5, 20"monitor, it was on again/ off again. then it was off
again/off again.
It's fairly new, and has about 10 parts/ square inch by the time the
filament heater gets to CB w/ flyback, and I have no schematic, so....
I tapped off the CB w/ flyback and cut the original traces and am running to
externally located bench PS, 6.00 volts, 0.4 amps, full floating, properly
grounded, works fine. I also tapped off the power switch w/ intentions of
installing a wall-wart power supply inside the plastic but outside the EMI
shielding.
I think that will be easier than finding the real problem, as the crt heater
is marked plus and minus and when the monitor was working it seemed to drop
to 5.3 volts when it went into energy saving mode. No bad solder joints on
board visible.
Any suggestions or warnings will be much appreciated.
Thanks,
Chuck Chandler
Blacksburg, VA.
again/off again.
shielding.
board visible.
Thanks,
Chuck Chandler
Blacksburg, VA.
