Ah good to know. Didn't want you poking around in areas that could radically alter your hairstyle
In my experience with CRT-based TVs (it's been a while now)
Loss of picture is often due to the high voltage disappearing.
An easy way to verify, I run the back of my hand across the front of the screen, and if I don't feel the static field, I assume the HV is off.
Because it's intermittent, it's probably not a bad horizontal output transistor, so I'd suspect a bad solder joint in the high voltage section. Have a close look at the flyback and horizontal sections for cracked joints.
Also, since it's intermittent, when the picture disappears, try tapping/flexing the PCB with a long non-conductive tool or wooden stick, to see if you can determine if it is a bad joint.
