Larry said:
After its running.....
By the way, this wonderful piece of technology is the rhythmic buzzing
sound in a regular, very annoying pattern ONLY on Channel 16 where it will
cause the most interference....
bzzzt....bzzt....bzztbzztbzzt.........(repeats every 3 seconds or so)
Took me a while to figure out where the damned noise I couldn't squelch out
was coming from. Shut off the fridge's 12V....noise gone.
Consider yourself VERY lucky if you can't hear it. Check your antenna and
VHF range, just to make sure it's working!
We never got rid of that little bzzzt noise. You cannot shield it out.
I since called "Louie" at the Connecticut outfit that bought the Adler
Barbour refrigeration business and he told me that the 11.5v minimum
restart voltage is the voltage at the compressor terminals when only
loaded by the 200mA condenser fan however the 7.6A starting current must
not pull the voltage down below 10.5v or the system will go through
another wait and test cycle. This is a much less stringent condition
than I had assumed and accounts for why the system now starts and runs
fine on one battery w/o charging source. Before rewiring the
battery(ies) had to be charging for the 'fridge to restart.
I had not noticed the ch16 interference but then I rarely monitor the
channel despite the law, I am usually more interested in the VTS
channels 5 & 14. Incidently the 16' pair of wires is twisted to minimise
rfi, perhaps that helps.
Dick
