Hi guys, newbie on board!!
We've recently installed a cctv system at work, which because our power supply normally comes from a generator, we've connected it to an old 110vdc emergency lighting central battery unit so it will operate when the generator is off. It seems the low voltage cut off is set at 100v which is not enough to last over the weekend. It has an adjustment on the potentiometer to either lower or raise the cut out point. My question is: How can I tell what voltage it is being adjusted to, or is it a case of try it and see?
Any help would be appreciated.
