Hello all,
I have a project I would like to do, and I think it should be fairly simple to accomplish, but my googling has not led me to an answer. Basically I want to develop a switch that will pulse.
Here is the basic operation:
A simple momentary button will activate it
when this button is NOT pressed, the switch will simply be a normally closed circuit
When the user presses and holds the button, the switch will pulse open until the user releases the button.
This pulse will be adjustable.
For example, the circuit is closed and working normally, the user holds the button, the switch goes open for .001 second, then closed for .100 second, open for .001 second... etc. then the user releases the button and the switch goes closed completely again.
The switch will be used by a 12V DC battery. It should see at the very most around 30 amps.
Any help would be great!
Thanks,
Clinton
Thanks,
Clinton
