Subject: Re: Ademco Vista-10SE lost master code
[email protected]
Date: 2/9/2004 1:16 AM Eastern Standard Time
Message-id: <tBFVb.446179$X%5.204354@pd7tw2no>
anomynous said:
Are we talking about the Vista 10 or Vista 10SE? Vista 10SE has seperate
Installer and Master Code. The Ademco site shows how to change the master
code using the Installer Code.
http://library.ademconet.com/ademco_group_user/FaqMain.asp?objid=12740466
This is under the FAQ section, not the secure section where you need a
username and password.
Vista 10SE does in fact have unique installer and master codes. It's been a
while since I've worked on one. We mostly use Vista 50 and 128's.
If you can get into programming (as Tom described above) you should be able
to reset the master code by following this procedure:
From the "20" prompt, press [#] [2] [0]
The next four digits you see scroll across the screen is the "installer
code".
Press [#] [9] [9] to exit programming mode.
Follow the procedure for programming the new master with the installer code
from the link provided above.
Don't tell your son what the master code is. Give him his own code if he
wants to fool around with the system. If you're still under contract with
an alarm company and they've locked out programming, you're going to have to
get one of their techs to come in and change the code.
Mike Said:
Steve Ryckman would be proud of Frankie Boy discussing master codes in
