Ademco 6150RF Relay Programming
Randy
Is it possible to program the relay on the 6150RF using the system
programming in a Ademco Vista20p panel. I'm unable to locate how to
assign the relay number as it looks like you can only assign a relay
to an output device with an address of 07-15 which limits system
programming to a 4229 or 4204. Is the only way the 6150rf relay can be
accessed is by using local keyfobs which are programmed only at the
6150rf itself?
Or have I missed some configuration on the 6150rf or the panel that
will enable recognition of the relay on the keypad or receiver address
, in this case either 00 or 18?
G
G. Morgan
Someone named [email protected] (Randy) Proclaimed on 30 Apr
2004 22:55:33 -0700,
6150rf itself?
I think so. AFAIK that on-board relay can only be activated with a
programmed button on the fob.
Are you trying to throw the relay on a system event as opposed to a
keypress?
-Graham
Mark Leuck
6150rf itself?
Nope you cannot program the relay on the RF keypad in system programming
must use a 4229/4204 relay
