Hi everyone, this is my first post. I don't see a beginners' section to start a new thread, so I'll post here, as this one seems very relevant.
I recently modified my old car stereo to create an AUX audio input, by mounting a female 3.5" jack to the head unit and soldering connections from it directly to the PCB. It works, and the sound quality is great in general, but there are some issues that I need to understand and resolve, and this is where I need your help.
The concept was to be able to use my mobile phone as sound source, by connecting its headphones output (also 3.5" female jack) to the head unit, with a simple "patch" cable. The main issue is that when I first plug the cable to the phone, it correctly indicates "headphones connected", but when I plug the other end to the head unit, the phone "loses" the "headphones", and any subsequent music reproduction occurs only from the phone's speaker; no signal is sent to the car stereo (*) although both ends of the cable are connected.
Then, in order to get sound as intended (from the car's speakers) I need to unplug the cable from the headunit, while music is playing, and plug it in again. It doesn't work if I unplug it from the phone. Only from the head unit. However, this seems to be an issue with the phone, since a portable mp3 player that I tried, will work no matter which end of the cable I reconnect.
The point is that, either with the phone or the mp3 player, once the source starts playing, there is no sound from the car speakers unless you reconnect the cable at some end. If the source was already playing when I first connect the cable, then no problem!
What is even weirder (or at least, it seems to me) is that, when it's all playing fine, if I stop playback from the source for a while, the same thing happens: I need to reconnect the cable at some end, or music won't come off the speakers. Can anyone explain why this happens? I'm sure it will prove to be the "expected behavior" afterall, but I can't get my head around it.
My best guess is that, somehow, the original signal path in the car stereo takes over when there is no input from the AUX IN, (although its volume is set to minimum, therefore inaudible) but why do I need to reconnect the cable? Is it a problem with the ground?
Another minor issue is that I get a lot of static/crackling noise whenever I plug the cable. I remember this could be remedied with a capacitor in series at the input, right after the jack... correct? Anyone remember any ballpark figures for line level audio?
(*) I suppose that no signal is sent (I have not measured it with a multimeter), based on the fact that my phone cannot play audio simultaneously from both the speaker and the headphones.
Thank you in advance for any answers, I did my best to describe the problem as simply as I could, I hope it makes sense... Also, please try to keep the words small
and the terminology to the minimum, english is not my native language and I don't have much knowledge about electronics... it had been quite some time since I last did any soldering... Anyway, any insight is highly appreciated. Thank you
edit: I was planning on uploading a schematic, but it's quite simple. 2 connections from the female jack's tip (T) to 2 points on the PCB (for the front left and rear left speaker), 2 connection from ring (R) to 2 points on the PCB (for front right and rear right) and 1 connection from the sleeve (S) to the chassis for ground.
[Mod Note: placed in a new thread]
