I have a 2003 Mitsubishi with a MR587268 AM/FM CD player. I'd like to add an input for playing things like my phone & MP3 players thru the car's audio system. The player has an input for an optional trunk mounted CD changer, which I do not have. This connection contains leads I am assuming are for left & right channels (labeled "CD-CH Lch" & "CD-CH Rch", in the service manual) as well as "Signal Ground" (see attached). Seems like these would be usable input paths. If so, how would I "tell" the player to use that input, rather than the tuner or build in CD player, when I wanted to use an MP3 player? I do still want to be able to use the stock radio/CD player. Is there a better way to accomplish this goal? I used to get inputs into the amp in a TV, radio, etc. by connecting to the volume control wiper/center lead. Thought I could do that with a jack that's switched to disconnect the lead presently connected to the wiper & connect the MP3 leads when the 3.5mm plug is inserted. Ideas???
The specs for this player state that a feature it has is "CD-CH, MD-CH control". Not sure what this refers to, I'm wondering if this relates to switching between the "CD Changer" & the tuner/single disk player?
TIA
DDD
TIA
DDD
