David Collier
I'd like to add a removable memory card ( 128Mbytes or more I suppose )
to my tentative design, which uses the AT91SAM7x128 processor. As far as
I can see the processor has no in-built assistance for communicating
with a CF, MMC/SD, smartmedia or any other external flash device I might
consider.
In particular I can't instantly see that I can output a read or write
strobe so I may have to bit-bash the whole dratted read and write
cycle... though you may know better.
I've designed ( on another project), but never built, a smartmedia
interface, which requires about 12 pins. I could handle that, and I
could use it for a soldered-on NAND flash if I liked too, so that's a
bonus.
I believe the MMC/SD card has a serial mode which looks a bit SPI-like,
but I know nothing more about it. Anyone know if you can actually use
all the memory over that interface? Is it SPI?
The ideal would be a 2cm square device with a nice simple interface,
which corresponds to a nice simple interface in the 7x CPU which I don't
happen to be using.
Anyone got any suggestions, or know of any Atmel/other application notes
on the subject?
David
consider.
bonus.
happen to be using.
on the subject?
David
