mook Johnson
I have a baby light and noise maker that is eating the three AA batteries
like mad. I'm looking to add a wall wart power input to it but still keep
the battery powered option.
Battery voltage is 5V and it drops out at 3 volts. Current draw is 200uA to
150mA at full load with the lights on and the songs playing
I'm currently thinking of using a dual shottky array that will drop about
..25V at 150mA. I have several 9VDC wall warts waiting for something to do.
I measured the smallest one and at 150mA the voltage is very close to 9Vdc.
A LM7805 (to-220) will drop the voltage to 5V then the diode will drop it to
4.75 which would be near perfect.
The problem I have is that the regulator will be in a closed plastic battery
compartment with no airflow and nothing to heatsink it to except the metal
DC input terminal.
Therefore the regulator will dissipate 4V times 150mA (600mW) at full load.
will that get too hot in that closed compartment? Will it melt the plastic
over long term use?
Any other low cost approaches?
DC input terminal.
over long term use?
