Hello,
I have 2-18GHz MMIC amplifiers that I buy off the shelf
from companies like Velocium and Hittite. Pretty small signal
stuff, like at max 18dBm output, although sometimes I'll compress
them, so it's not all Class A.
The data sheets ask for a nominal drain voltage, but since all the amps
have different values, what I end up doing is supplying them all
from one +7VDC regulator, and use various dropping resistors to
target the desired Vdd (usually around +3 to +6 volts),
based on the average operating current (around 50-150mA or so).
There are plenty of decoupling caps on the regulator side of the
resistors,
so a good AC short to ground is maintained.
My question is can I consider the action of adding a series resistor
to the drain supply (thereby making them more like current-sources
instead of voltage sources) a method of adding built-in temperature
compensation to the amplifier?
It seems to me that as the transconductance goes down with colder
temp, that there will be less current and less voltage drop across the
resistor, and so a higher drain voltage.
Thanks for your input.
Slick
resistors,
Slick
