Hi! I just bought a power amp for my sound system and I would like to add a preamp out to my stereo amplifier (Sony str-vx450). I have the schematics and I believe I know where to add my RCA connectors. However I'm not that knowledgeable in electronics and I don't want to mess things up...
There is a left and right tone amp out going to the power amp, that's where I believe I should intercept the signal - just before driver impedance det IC701
There are two jumpers in that region on which the voltage modulates with the volume rheostat from 0.006v to 1.5v is that the best place to solder my wires? Would it be cleaner to simply connect to an existing connector? In that case I can't see which one...
Also, where should I take the ground for my output? Directly on the chassis?
Thanks for helping! It is greatly appreciated!
