adapt a 3 amp battery charger?
I have a cheap battery charger that I have had for a long time. It's
rated at 3 amp/12 VDC. I've used it over the years to keep a variety
of lead acid car batteries charged during periods of battery
inactivity. It's worked fine for that, as far as I can tell.
The markings on the charger are:
input 60 cycle .6 amp 117 VAC
output 12 VDC 3 amp Full wave rectifier
If I put a digital voltmeter on the charger leads, when the leads are
NOT connected to anything, I show a reading of 13.56 VDC
I have a real small "nominal" 12 volt lead acid motorcycle battery,
rated at 10 amp/hour.......that I want to charge. I'm told I should
use a maximum of 1 amp current to charge this little battery.
Is there a quick and dirty way to adapt my 3 amp charger so that it's
limited to 1 amp for this cycle battery? Keep in mind that the charger
is a cheap one, and almost for sure not sophisticated in any manner.
Thank you...... Lee Carkenord
John Fields
mike
Light bulb works too. Tail light with both filaments in parallel.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Ross Herbert
What you need is an add-on charge controller for your cheap battery
charger. A kit is available from Jaycar in Australia for just such a
device. (watch out for line wrapping)
http://www1.jaycar.com.au/productVi...2=K&pageNumber=&priceMin=&priceMax=&SUBCATID=
