Design a circuit using op-amp that will reject the 60kHz power line noise and also reject high signal frequency above 800Khz. The stop-band width around the 60kHz centre frequency is 10kHz. Use a cascade of 1st order high pass and 1st order low pass filter to implement this circuit. The voltage gain at passband frequencies is 10.
As mentioned in the title, can sum1 tell me this should be a band reject or band pass filter?
i try to construct a band reject filter but the result seem like not correct.
here is my circuit using multisim
here is the result using AC analysis in decibel
can sum1 help me out of this?
thanks
thanks
