I would like to build a drum machine/metronome
using a BASIC Stamp 2 (maybe later on PICAXE)
which would allow the user to control
the beats per minute (bpm) with a dial/potentiometer.
They could select a value from 1-255
(later I might add a module to display the current value).
I would like the timing to be as accurate enough
to a real clock to be comparable to a real metronome
or drum machine.
This is the main problem, since the BASIC Stamp 2
(and PICAXE models I am considering)
don't have a real time clock (see link/citation below).
Would I need to connect the microcontroller to a
Dallas real time clock to accurately control the timing
or would it be possible to make my own with a
555 timer or other component for less money?
For my purpose the 555 or similar would have to be
accurate enough to measure actual seconds
(or milliseconds? how granular should it be?)
to get real beats per minute.
I have found numerous "555 calculator" pages
(some listed below) which let you enter different
resistor/capacitor values and see what the
time high / time low would be (you can reverse
the math to figure out what R/C values to measure
milliseconds, or 1/100 of a second, or whatever
would be accurate enough).
You can get gold resistors with +/- 5% tolerance,
would this variance throw off the timing?
Furthermore I read that capacitors of the type needed
for the 555 are a lot less tolerant (+/- 20%)
than gold resistors. If this is true, would this
totally throw off the timing? I picture myself having to
buy 100 capacitors and test each one with a meter until
I find the exact value, and even then its capactiance might
change as it ages, making the device not accurate.
Any advice or links to a similar project or good solution would be
most appreciated... The simpler the better : )
Thanks again
Shaun's Basic Stamp II Beginners Page
http://www.geocities.com/SiliconValley/Orchard/6633/started.html
Real Time clock (RTC) - Since the Stamp only uses a resonator for its
clock,
it is not accuarate enough to keep track of dates and times.
Resontors usually have a +/- 1% error, that means over a 24 hour
period
error could be close to an hour. But since the Stamp usually only is
working with milli seconds, mirco seconds,and seconds a resonator
does
the job. Real Time Clock can keep track of years, months, weeks,
days,
hours, minutes, and seconds. So as you can see any project that
requires
an accuarate time base then a RTC is what you need. Dallas semi
conductor
make some of the most popular RTC's. www.dalsemi.com
555 Calculator
http://freespace.virgin.net/matt.waite/resource/handy/pinouts/555/index.htm
555 Timer Calculator
http://wolfstone.halloweenhost.com/TechBase/com555_555TimerCalc.html
http://ourworld.compuserve.com/homepages/Bill_Bowden/555.htm
or drum machine.
Thanks again
clock,
period
does
days,
requires
conductor
555 Calculator
