Hi
I need help to make an access controlled turnstile gate work......![Er... what? o_O o_O](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(I have some electronics knowledge/experience, but not that much)
In theory I should have all the components needed to make it work - it is a salvaged turnstile...as far as we know all components are still functional, but unfortunately the wiring is non-existent....so the problem is to figure out how to connect everything to make it work.
The components we have are:
- Physical turnstile ("Walk through" type turnstile - I've attached a picture as an example, the one I have is only an older more square type version)
- Transformer (In - 220/230V, Out - 24V)
- 2 x "Solenoid" type components (See photos attached/below)
- Breaker with connection points
- 2 x 12V Relays (Hella 4RA 965 400-00)
- I have separate access control devices that can be connected to the gate once I have managed to figure out the gate wiring. I will be using ZKTeco SF300 devices, but they are easy to wire and connect, getting the physical turnstile wired to work is the big problem.
The end result I want is to basically connect an access control device to the gate (on each side - in/out) and then when someone swipes their card or press their finger (biometric access) the gate will unlock and allow the person to walk through the gate and then the gate will lock afterwards (obviously this delay is set in the access control device).
So far I have managed to connect 220/230V to the "breaker" and then also from there to the transformer - from there I have no idea how to proceed![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you,
![20114314380413.jpg 20114314380413.jpg](https://makerv2.webteractive.co/forums/data/attachments/21/21950-cdd350e7ece9ffdd0e43ab02cb0f5f8a.jpg)
![44.JPG 44.JPG](https://makerv2.webteractive.co/forums/data/attachments/21/21953-ee835257b0558834f5952bbdc13b2917.jpg)
![22.JPG 22.JPG](https://makerv2.webteractive.co/forums/data/attachments/21/21951-eacae6c9e3721eb92c189dfda3dbf10d.jpg)
Thank you,
