I am analyzing an AC signal of 220V rms and 60Hz frequency. I have to clip the wave from below, i.e. eliminating the negative cycle (using simple half-wave rectifier). Then I have to clip it from above as well. I have to clip it from above as well. Clipping from below was easy. But while clipping from above I have to make certain that I apply such a biasing voltage to the rectifier that the power of the signal remains 10W across a 484Ohm resistor.
For the resulting waveform, I have to calculate the value of biasing voltage, i.e. the amplitude threshold of the wave so that the power across the resistor of 484Ohm remains 10W. Any ideas, please?
