230VAC Wall adaptor Output ~ 9VDC 1A, I was wondering if using this when my circuit only uses a fraction of 1A would do any damage to anything. I was thinking that only the required amount of power would come through the adaptor and that the 1A rating was a max. If not, can i use a resistor at the start of the circuit to lower the current from 1A to how ever many milliamps i need?. Thanks
Code:
9V--------------150Ohm-------------20mA-----------20mA----------------20mA-----------------0V
-------------------Motor---------------------Potentiometer-----------------------
| 100Ohm |
--------------Motor------------------------Potentiometer-------------------------
