Platforms
Content
That is essentially a solid state relay, though it may be realized discretely, not as a single component.TRIAC isolated from the microcontroller by an opto-isolator
One that fits:there are many type of relay's which one select to control 0.5 H water pump
pump motorOne that fits:
- max. current required by the motor/pump (with some spare for a safety margin)
- max. operating voltage (with some spare for a safety margin)
- your purse (with some spare to support living)
I just asked for confirmation and safety. I have no doubt, the specification of relay match with pump water requirementYou have all the data of the motor, compare with the data of the relay. Where is your doubt?
This is not recommended due to current consumption and possible flyback voltage from teh relay coil. Use a transistor in between.can we interface relay directly to 8051 port
which transistor I have to used to interface relay to mcu , also where to connect two wires of motor?Using the 2n7000 imposes no load on the μp port, it is designed to interface with 5v circuitry.
M.
