N_Cook
Went to use it this week , first time for ages and not a dickybird, no magic
smoke/ ominous noises. Just single cycle slow repeat ping/clicks from the
inverter transformer. Was working fine last time of use.
Anyone happen to have schematic of the ABI DDS-40XP Digital Diagnostic
System or more pressingly the SMPS, I only have the ABI user manual
I may be able to get away with 2 SMPS replacement fitted in there, the
Coutant (maybe type number B91510 ) from 1988 uses a lot of early days SM ,
seems very high power, I suppose for the situation if all 118 relays are
active at the same time plus CRT plus floppy drive.
-12V,1A
+12V, 3A
+5V,12A
and a separate +5V,5A
I'll have to confirm this ps does not require a load to start up, unlikely,
but not done so yet , no obvious fuses on main board .
So far cold checked the smps and nothing amiss on Rs,Cs or large active
Uses UC3842 supervisor, plenty of data, so should be able to confirm the
oscillator part of things easy enough.
-12V,1A
+12V, 3A
+5V,12A
