AAAA Cell holder - Am I Asking Too Much? - Test Post
  • Thread starter Watson A.Name - Watt Sun
  • Start date
W
Test post - new server, new ISP, probably sucks as much as the other
one, so here it goes. A repost.
I had some 9V alkalines that were only 7 or 8V, so I opened them up to
get the snap contacts. I found that of the 6 AAAA cells inside, only
one was bad, the other 5 had some life in them. So I decided to make
up a throwaway LED light, by soldering three AAAA cells, a resistor
and white LED, with some black electrical tape to hold them together.
I tried to solder a wire onto the top of one of the AAAA cells, but it
went PFFFT! and the top popped off and spat hot juice out. At which
time I said, maybe this isn't such a good idea, and went to the bench
and rigged up a battery holder. I cut out some springy metal
contacts and drilled some holes and mounted them to a piece of blank
PC board, and now it holds the single AAAA cell, and now I can run one
of my V boost circuits from it. But I've got better things to do than
make battery holders.
I Googled for "AAAA battery holder" and checked out pages and pages of
hits, but I still haven't been able to find an AAAA cell battery
holder. I've tried different combos of the words in "AAAA cell
battery holder", with and without the quotes, but I haven't been
successful. Mostly it comes back with "Nothing found. Did you mean
AAA cell holder?" I would even be satisfied with an AAAA to AAA cell
adapter. But the "AAAA AAA cell adapter" comes back nothing found.
When I do get hits, they're only for products that use the AAAA
cells.
I've been to Keystone Elect. http://www.keyelco.com/kec/pdfs/p12.pdf
and checked these contacts, but that's not what I want. What I'm
looking for is similar to one of these, but smaller.
http://www.thomas-distributing.com/battery-holders.htm
I'm looking for a plastic holder with wire leads for 1, 2, 3 or 4 AAAA
cells. Am I asking too much?
UPDATE
I've been 'using up' the AAAA cells that I removed from the 9Vs, and
they are all popping open. The top (negative) with the button pops up
and sometimes lets the juice out. Sometims I can push the top back
down and get some more life out of the cell. One ran all night long,
and I got up this morning and it was still running the V boost circuit
but the LED was quite dim. So I measured the voltage and it was down
to 666 mV, still running the circuit but just barely.
So where, oh where have all the AAAA cell holders gone?
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Michael A. Terrell
W
I'm now able to download the full pics that have been posted to ABSE.
Before, the multiple section posts always had some sections missing.
So at least this new ISP has better Usenet newsgroups service.
cells.
UPDATE
