i am a complete beginner and i would like to make a LED light, that turns off during the day.
I have found this diagram online, which seems simple enough.
- This shows a switch that turns on during light, so id have to change LDR and R2
- I would like to use a LED instead of an LDR (found online you can do that and i find that interesting and want to try it, though it uses mosfet)
Here are my questions:
- passive consumption > wouldnt this design consume power even when the LED is off due to the circuit being basically shorted through a resistor?
- Could it be modified to not consume any energy when dark?
- is the R2 even necessary? if there was no connection it would be equal to indefinitely large resistance and still would work if the LDR resistance is high enough since it could possibly cut off the connection entirely? Obviously here its a potenciometer which helps adjust the threshold but i am just curious.
- would i have to change anything in the math if i added a few more LEDS in paraler?
I would like to make a long lasting battery powered outdoor light, so its important it doesnt waste energy.
Eventually itd be nice to have it with a small solar charger but i dont know anything about that, as this already is beyond my knowledge.
Thank you for any help
![LDR-circuit-improved-1024x729.png](/forums/proxy.php?image=https%3A%2F%2Fwww.build-electronic-circuits.com%2Fwp-content%2Fuploads%2F2013%2F11%2FLDR-circuit-improved-1024x729.png&hash=72ddac01719d294e57330f3987d28553)
