E
Eeyore
Looking for an inexpensive commodity dual comparator that's a little quicker
than the ubiquitous LM393.
Suggestions ?
Graham
Suggestions ?
Graham
I always have problems when I build a LM393 on strip board prototypesLooking for an inexpensive commodity dual comparator that's a little quicker
Suggestions ?
Graham
Martin said:I always have problems when I build a LM393 on strip board prototypes
with MHz oscs on the transistions. I've tried the usual positive
feedback tricks, etc
Is it just me?
Eeyore said:Looking for an inexpensive commodity dual comparator that's a little quicker
Suggestions ?
It might be. ;-)
I generally have very good luck with plugboard prototypes
using the LM393.
John Popelish
Graham said:Looking for an inexpensive commodity dual comparator
that's a little quicker than the ubiquitous LM393.
Suggestions ?
Graham
Winfield said:The LMV393 may be slightly faster. I like TI's
cmos TLC3702 version, with active-pullup outputs.
Although it's officially slower than the LM393,
in some circuits with high-value pullup resistors
it might be faster. The TLV3702 is an attractive
nanopower version that's quite slow. Yawn...
Winfield said:Ah, I forgot about the max907, same pinout, but very
fast, almost 100x faster than the lm393. Sadly Maxim
has discontinued it: "This product was manufactured
for Maxim by an outside wafer foundry using a process
that is no longer available." But if you want to give
Maxim another chance, their max942 is about 5x faster
than the lm393 The max942 has an active pullup. The
miniDIP is $3.62 at Newark. Free samples from Maxim.
Or you might try TI's tlc372 and tlv2352 parts, they
are cheap and may be a bit faster than the lm393.
Is it just me?
John said:The LM319 dual is not a drop in replacement, nor a similar
design with just higher speed. but it is faster.
http://cache.national.com/ds/LM/LM119.pdf
Just about to wire up a bit of stripboard that I managed to find, withHard for me to say. The last time I used stripboard was 1990.
Graham
Which LVDS parts do you use?LVDS receivers are ns-speed comparators for around 50 cents. They do
tend to have built-in DC offsets.
John
Martin said:Just about to wire up a bit of stripboard that I managed to find, with
a 74HC221, a 74hc86 , lm393 and an AT89s4051 so that I can decode
smpte timecode played from a laptop. It's not worth waiting for a pcb
from Olimex
Not recently, but Olimex is generally fine for me, this will be upHave you looked at pcb express ?
Graham
Martin said:Not recently, but Olimex is generally fine for me, this will be up
and programmed by tea time today, I only decided I needed it yesterday
afternoon, after a couple of mugs of rioja
check your emailDo you find Olimex a good prototype/small quantity production supplier ? What are their
turnaround times like ? Any info gladly received ! I'm looking for a decent supplier
right now. What CAD file formats do they support too ?
Graham
Eeyore said:Thanks.
