here is the circuits picture.
http://www.flickr.com/photos/26914086@N05/2519852045/
I build a deadbug circuits of it. However, the MOSFET is not fully on
or off, the lower drain waveform is shown on the right bottom. it
should be an inversed gate waveform.
load is a photodiode with voltage drop of 2V / 10A.
Is't caused by some parasitic inductance? I couldn't figure out the
parameters. Here I use these equations to calculate the L
V=L di/dt
dt = D/f
di = current ripple
V = Vcc-Vds_on-Vload
but the original circuits use two inductors, why?
Why here are two anti parallel shottkey diodes? I don't think it's
necessary. one is protection and the other is "free wheeling"? Is this
high-side driven a "buck" configuration? I removed the shottkey and
the waveform doesn't change too much.
Why there are two capacitors? local voltage reservoir? can I pick any
large capacitors? or I need to use equation
i=Cdv/dt
dt=D/f
dv=di*Cesr
i=10A?
from IXDD414, the output is shorted by 1k to ground, I don't think
it's necessary.
I am totally confused by the TVL4112 comparator and two FET current
mirror(?). How does is work? I know the comparator show be high or low
but here it will follow the input voltage until the + and - are equal.
How does the feedback work? on the top the current sensing gain is 20
if I remembered. how to calculate the current here? apparently a LM324
won't work as a comparator.
Thank you guys.
Have a nice holiday.
V=L di/dt
dt = D/f
di = current ripple
i=Cdv/dt
dt=D/f
dv=di*Cesr
i=10A?
it's necessary.
Thank you guys.
