Actually, it's a pretty simple question that I wanted to ask. The DC power supplies which we often use in like labs or with some DC operated electronic equipment has its ratings written on it. For example, a DC adapter that I use with my internet modem has a rating of 12V 1A. The question is, that if I am to make a power supply by myself and I need to calculate the parameters, how exactly would I do that. The voltage calculation is pretty simple but what I am confused about is the current. How would I calculate the output current of the power supply that I want to make? If I were to make a power supply with 30 volts 5 Ampere output, how exactly would I figure out that the power supply has an output rating of 5 Amperes? Does it depend on the transformer rating that I am using for stepping down the voltage or load or both or some other thing?
Thank you.
Thank you.
