8 channels ADC 16Bits
  • Thread starter Habib Bouaziz-Viallet
  • Start date
H
Hi all,
I'm seeking about a single chip ADC with
- Eight 16Bits channels,
- mini 250 KSamples/s,
- good linearity, low dist, ... etc,
- simultaneous conversion (but no simultaneous S/H),
- preferably parrallel interface.
I would appreciate if someone could share some experience.
Thanks in advance,
Habib
H
Vladimir said:
Hi Vlad !
I was recently looking for the similar ADC. There are not very many to
choose from. Consider AD7606/7608/7609, ADS1178, or a multichannel audio
ADC.
I think the AD7606 is quite good for doing the job, Hobbs is sight
saying sampling simultaneously only relevant.
The AD7606 parrallel interface is just what i need in order to interface
it with an FPGA or uC. In fact the project is facing an parts
obsolescence of 32 analog channels card in a 6U form factor (like old
VMEBus card).
Many thx,
Habib
H
Michael said:
Habib -
Watch out for the low pass filter in the 7606 - great if you need it but a
disaster if you don't (unless there is a way of bypassing it which I can't
see).
You are absolutely right. 15KHz BW over 5V applied by this LoBand input
filter in the AD7606 (No Oversampling). Fortunately the bandwidth
signals in the project did not exceed 12,50KHz.
Thank you pointing me this issue. It may becommes a nightmare if
bandwidth signals was over 15KHz or something ...
I hope there are no other traps that will drive me crazy. I will read
this datasheet more carefully tomorow.
Thanks,
Habib
Joerg
Another trap is the ground structure. Splitting the plane is usually a
recipe for additional noise in the data.
H
Yup ! Must be considered later during stackup PCB implementation.
Splitting power planes is generally a good choice among others for mixed
signals systems although these PP have to be decoupled each others. Thanks.
Habib
Joerg
Power plane splits can make sense. But one must be 100% sure about any
sequencing conditions that have to be met during power up and power down.
H
Joerg,
Are you sure there is a special power up (and power down) sequencing
requirements for this chip ? Nothing is noticed in the datasheet and
evalboard zip file.
There are only two rails AVCC (ref to AGND) and Vdrive ref to separate
GND from analog domain. what sequencing conditions ? Please be more
specific, i did not understand.
Habib
PS : Sure there are power up requirement for chip with multiple power
rails (+AVCC, -AVCC, Vcore ...etc), nothing similar for this simple ADC
chip.
Joerg
Joerg,
evalboard zip file.
On the AD7606? It is on page 11 of the datasheet:
http://www.analog.com/static/imported-files/data_sheets/AD7606_7606-6_7606-4.pdf
Abs max says that Vdrive (the digital supply) must not exceed
AVcc+300mV. So it looks like you have to make sure Vdrive doesn't come
on first and exceed AVcc, and use similar caution when powering down.
Otherwise, most likely some diode path or BE junction will come on and
only Analog Devices engineers would (maybe) be able to tell you whether
that ends in chip damage or just some lock-up scenario.
Looks like it is best to make Vdrive not come on until AVcc has come up
to spec'd value, and then also make sure that Vdrive never exceeds AVcc
later. I am not sure whether this is also critical during power-down and
I would ask Analog Devices. If it is critical you could, for example,
use a cheap POR/BOR chip (NCP3xx series, for example) to bleed off
Vdrive fast the instant AVcc falls below, say, 90% of its value. If you
do it in a clever fashion you can also let this POR/BOR chip handle the
power-up situation.
Habib
chip.
Well, the AD7606 does have two power rails, one for the analog parts
(several pins) and one for the digital part (pin 23), along with
prescribed conditional boundaries between the two. Abs max data is
usually something that needs to be taken seriously because it can mean
that permanent damage might result when exceeding values in that table.
H
to spec'd value, and then also make sure that Vdrive never exceeds AVcc That makes sense.
power-up situation.
Once more, thank you very much for your help.
Habib.
