I have got one doozy of a headache from some 74HC595 issues, and I was hoping you awesome people could provide some insight...
I bought about 10 of these "74HC595N,112" from digikey in two separate orders through two separate weeks in order to run tricolor LEDs with a common cathode.. they are labeled on the chips with:
"P 75HC595N
X L2L2R4 11
N UnG1310D"
The datasheet for those 74HC595 are on the digikey site linked above, the datasheet for the LEDs (the best I could manage to get) are going to be here, and the datasheet on the buttons are here.
I have hooked these chips up on several types of breadboard according to the common circuit designs that are easily found all over Google attempting to get them working after initially checking with the datasheets for my product to verify their validity.. and they will not operate correctly. I'll attach a video of one of the times they acted strangely, but other times they just randomly turn on and off connections where most of the time the outputs are all completely on, and the "Q7S" serial output is running in a High state as well..
I have tried using USB as a method of powering these, as well as a computer power supply with a Molex connector hooked up to the board. I know that the buttons I'm using are not damaged, and are not acting poorly as I've hooked up a multimeter to all of them to test. I also ordered 10 of those buttons in case some were damaged. In addition I've tested to make sure none of the lines on the breadboard were incorrectly electrically connected while there was no power on my board using a multimeter.
Did I buy some sort of bad offshoot of the 74HC595 that isn't working the way I'd expect being that they're labeled as "74HC595N"?? I had assumed this was just a manufacturers part number that differed from manufacturer to manufacturer.. are these chips all damaged despite being shipped separately? Can anyone help me?
This is a link to the video (new phone, excuse my novice upside down video).
This is a picture of my breadboard attempting to get these to work properly:
"P 75HC595N
X L2L2R4 11
N UnG1310D"
