Anthony Fremont
Hello all,
I'm tinkering with a 74HC299 and I'm having a bit of trouble. I am just
using it as a serial-in/parallel-out shift register. Whenever I clock
in 1 bits, all is fine. As soon as I clock in a single 0 bit, all the
output registers reset to 0 simultaneously as if I had driven the reset
pin low.
I have both OE pins tied low as I don't need the output pins blanked as
I set them up (maybe this is the problem?)
The reset(clear) pin is tied permanently high
I've tried left shifting *and* right shifting with identical results
Both serial input pins (left and right) are pulled up (I've tried them
pulled down too)
The cascade outputs are floating
..1uF and 10uF bypass caps on power pins
The datasheet is not real descriptive, but I think I got it hooked up
right. I even tried another chip with the same results. Obviously I'm
doing something stupid here, but I just don't get it. :-(
In summary: As long as I'm clocking in 1 bits, all is cool. The first
0 bit resets all the outputs. I hope this sounds familiar to somebody.
pin low.
pulled down too)
