I'm not new to electronics, been doing it on and off for about 40 years, but I am new to owning an oscilloscope. I used to experiment with 74 series chips in the late 70s when they were real TTL but I never saw what they did on a scope. All my projects (which were quite simple) worked fine. I also used 74HC chips 'unknowingly' about 20 years ago and that project worked fine too. I had no scope and just assumed all the signals were square waves. That project (a clock) ran at about 1Hz.
So, now I have a scope and recently I've been testing some 74HC series chips on a breadboard and I'm troubled by the output signal I'm seeing (attached). Specifically, I have a 1MHz quartz oscillator (MX045 metal package) whose output is connected to the clock input of a 74HC163 counter. I attached my scope to the Q output that gives a divide by 4 and results in a 250kHz square wave output. Well, at least I expected a square wave, but I'm getting a 'ringing' on the edges and some little spikes inside the wave. I have used a 0.1uF bypass capacitor and have tried to keep all the wires short. The supply is 5 volts.
After some reading (a lot of reading) I understand that this ringing is caused by reflections in the wire which are worse at high frequencies and happen more in modern CMOS devices that have fast switching. What worries me is the max and min voltages that the scope shows: 5.75 and -1.28 respectively. While fiddling around at one point I saw +8 volt maximum. That went away when I made the wires shorter and connected the scope ground closer to the chip. It worries me that this voltage is so high it will damage the chips. I'm also worried that when I build up my project with more chips, this effect will spread and stop the project from working at all. Am I over-thinking this and worrying about nothing? In all the searching I have done I can't find anyone saying that this is OK or not OK. It's like everyone seems to ignore it except when discussing long transmission lines -- but all my wires are short.
As an afterthought, could this be caused by the act of trying to measure the wave? I may not be using the scope correctly. I calibrated the probe with the trimmer tool and set it to 10x as described in the manual.
Thanks for any advice you can give.
John
John
