7404 Hex inverter stuck on 2.5v
I got a problem with the hex inverter. The idea is to clearly define the pulses coming in from a few optical encoders working on phototransistors, but I'm having a problem where 7404 output suddenly settles to around 2.5v.
Would anyone have any guidance on how i can fix this issue?
Many thanks
Morty
It's basic I don't have any external components such as pull up/down resistors
The inverter outputs will go into the MCU or a LS7084 clock converter that will take the A and B channels and make one pulse. I've yet to get to that stage to decide what will work best
Take everything off the chip and put 1k between input and 5v rail. What is the output ?
Put 1k between input and 0v rail. What is the output ?
