Feeling a bit stupid after the ordeal with my previous post but alas everyone makes mistakes.
Anyway to the point of this post: I wishing to make a 6 sided LED moodlight that uses straight RGB LED strips to be oriented in the shape of a hexagon, and to have each side illuminate in 6 different colours that are designated to its side.
Each side would illuminate one at a time for about a second in a circle fading into the next colour strip and fading out the prevous, then after it reaches the begining again after two rotations, they all illuminate for around 5 seconds and the cycle repeats to the cycling of colours again. the brightness intensity wouldn't be super bright but a more calm brightness so you can see its there but its not blinding you or causing too much distraction.
I know this would most likely require an audrino to run but have no idea where to start, have had a bit of experience dealing with audrino as ive had to do basic reprogramming of a MinimOSD for my quadcopter using one but otherwise am a complete novice at coding.
The Hexagon would look like this in this:
![Hexagon Mood light.png Hexagon Mood light.png](https://makerv2.webteractive.co/forums/data/attachments/39/39852-a9e0662f74679619458d48ce8601df42.jpg)
The rotation cycle would start at 1, fading into the next in line and go around twice until reaching 1 again, then all fade to illumination, then the cycle repeats, or could be programmed to cycle at random intervals.
