Hey guys
I was wondering if someone has a spare moment if they would would mind sharing their ideas as to why a makeshift 5 volt regulator transistor had a lot of heat being thrown off it with such a small load.
Scenario:
We're about to head to a camping spot to go camping, and I decide that the 4 port Cigarette lighter female socket hub should be wired into a live circuit instead of the circuit that is only powered when the notch on a an automotive ignition barrel is clicked onto the spot just before accessories so that things such as mobile phones, vape batteries etc can be charging off a single medium power 5v regulator (CV05 or somethingarather). Long story short - accidentally reversed polarity going to the hub as I just figured y'know, the black wire should really be negative and the black and white wire should be positive - this is standard practice right? Well, turns out it was the opposite for some reason which blew firstly the 5 volt regulator in G.P.S male plug. secondly the U.S.B cigarette lighter socket to u.s.b adaptor regulator and thirdly, an internal voltage regulator (Part of the hub) that has an external 5v u.s.b adaptor female socket. Lots of smoke, many sad. So 3 regulators blew and I had about 20 minutes to put together something that could power the g.p.s for a 5 hour round trip as well as at least one female u.s.b port for charging nicotine vaporizer batteries while camping.
So on a breadboard (Yep it was very unpretty!) with u.s.b female plugs duct taped to the breadboard lol. (Any port in a storm right? ;-))
I used a cv something 05 transistor & wired it with 12vin comming from anode from car battery/alt circuit into the gate/base terminal pin and tied the common ground to the drain/collector and emitter/source to positive 5v out.
This worked but the heat sink got mega hot, way too much than I would expect just to run a g.p.s and charge a vape battery. (Not sure how much they draw, maybe not much? I really should measure it sometime) Anyhow I only wired it this way as per a circuit diagram advised to wire voltage regulators but this is very different as to how an lm317 operates yet it still works? *Scratches head*
Had a look at an N.P.N schematic of bipolars or mosfets and the way it was wired I can't see how either of these could work properly unless I am overlooking something. Are these preset voltage regulator transistors in their own separate group and the wiring is completely different?
Any help would be appreciated - I don't think it should be throwing off so much heat that the heat sink is very hot to touch. (Pretty big heat sink for a medium power tranny too)
Regards -
Damien
Scenario:
Regards -
Damien
