555 timer reverse polarity circuit
Hopefully this will be the last version of this. The LEDs were moved into the constant current legs of the supply as ElectroBrain suggested. Like 12v walmart
************* Notes **************
All Resistors are 1/4W
All Disc Caps are rated >= 25VDC
C2: Electrolytic >=25VDC
K1: Can be any SPDT relay with a coil resistance >= 400 Ohms
and contacts rating >= 500mA
http://www.mpja.com/12VDC-SPDT-Essex-Relay/productinfo/18454+RL/
Hi CDRIVE. Please can you tell me how i can use this diagram from 30 v adapter which has only + and - which is standard adapter.
