50s/60s Transistor Identification
Found this site looking up info on 50's - 60's transistors and thought i'd see if anyone
has any information on a part I've yet to ident..
A couple of people said it may be an old Transformer??
Any help would be appreciated!!
Not sure, but for parts of that era, you might also try AntiqueRadios.com. It's another forum that I belong to that is all about old radios, but this would be something that I'm sure you would get an answer on rather quickly.
I'm of that era, but the part number doesn't ring a bell with me.
The pin-outs are numbered one thru eight, which would indeed indicate a transformer to me. But encapsulated components, especially military parts were common back then.
Do you have an ohmeter? You can check for resistance measurements to see if there are transformer windings inside (very low resistance measurements).
It IS possible, though unlikely, that it may have been a special-purpose part, encapsulating something else.
Good luck with the search.
You could try measuring the resistance between pairs of leads. If you find low resistances between 1-2, 3-4, 5-6, and 7-8, and high resistance elsewhere then it is likely a transformer.
Even if it differs from this a little it still may be a transformer, just with more complex windings.
Damn, originally typed about 24 hours ago, but I forgot to hit the post button.
