50H82 Toshiba noisy lines across pic.
Jason D.
Did the capacitors replacement in the hyper module got the color back
except I have noise horizontal lines across image on whole screen. It
goes away gradually as TV runs for several minutes after cold start
up.
Seen this before?
Cheers, Wizard
Jason D.
Jason How Many Caps Did You Replace On The Board ?
kip
Kip, all of them, made sure to use computer grade caps. Including 11
10uF 16V caps.
Cheers, Wizard
K
kip
Ok Jason ...I have done many and now always change all of them.
Check the socket were the Module plugs in resolder both the
socket and plug sections just to be safe.
What I did first was to photograph the Module so ,as when installing them
I didn't put any in backwards and good job I did because one time
I put one in backwards,best double check your work.
kip
