5 x 7 dot matrix led driver needed
simon
Bit of a tall order but here goes...
I need to display a fixed message on sixteen 5x7 dot matrix led
displays. My question; is there a chip(s) that will handle alphanumeric
decoding and multiplexing in order to keep current consumption to a
minimum?
Thanks for any advice.
Simon.
Spehro Pefhany
minimum?
Use a microcontroller. This can be done with the microcontroller, 3-10
driver chips and some MOSFETs. Current consumption will be dependent
on average LED current (and therefore the desired brightness for a
given display type), which has little to do with the drive circuitry.
Best regards,
Spehro Pefhany
simon
ELAL said:
Yep, the MAX6952 (contains everything for 4 characters, SPI bus
interface, can be daisy-chained for more chars.) is worth a look.
Two words: component count
Yes, I could have done the job with a microcontroller but I was after a
dedicated IC - if such a thing existed. I'll give the Maxim part a look
- thanks!
Simon.
Spehro Pefhany
- thanks!
Most often, when I look at the price and availability on these kind of
things, sadly, they cannot be justified. Perhaps this one is
different, but being Maxim, it would be something of a first... hmm..
I don't see it even listed at Digikey, which isn't a good sign.
You'll still need the microcontroller, obviously, regardless of the
kind of driver used.
The only (reasonable) way I can think of to avoid using a micro would
be to play around with EPROMs and address counters and oscillators,
and for this amount of memory the micro will be the better choice.
Best regards,
Spehro Pefhany
W
Wouter van Ooijen
and two words about the MAX6952:
- price
- availability
it scores :( on both accounts
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
W
Wouter van Ooijen
Use www.findchips.com
It shows only on newark, as special order item.
Wouter van Ooijen
http://www.voti.nl
simon
- price
- availability
Wouter van Ooijen
http://www.voti.nl
Oh dear, that's a shame - the 6952 was exactly what I was looking for
I must have a device that is readily available - looks like I'll have to
design a system myself.
Thanks to everyone who offered advice.
Regards,
Simon.
A E
minimum?
Simon.
Used to be Allegro made chips for that. UCN5832 IIRC. But they are hard to find.
W
Wong Sy Ming
You can order them directly from Maxim. Good service from them.
