Using a 5 pin relay in a 12 volt automotive system to run the fuel pump. The pump only runs a few seconds then shuts off. The pump is wired to pin 87 on the relay. When the pump quits, pin 87 (with the pump wire removed) has no power reading with a multi-meter. Pins 85-86 and 30 still have their respective power figures of 12 volts on 30, around 6 volts on 86 and ground on 85. There is a rocker switch on the dash that controls energizer power to the switch and 12 volts to pin 30 is controlled by the ignition switch. I've tried two 5 pin relays with the same results.
Platforms
Content
