4x4 keyboard to control computer
Chaos Master
Hi!
I want to make a 4x4 keyboard for my PC, to be able to control MP3 player
software (Winamp) and run programs. I want basical features like
play/pause/stop/next/previous MP3 and be able to run programs by pressing the
appropriate button.
Any ideas of what I could use to receive the data from the keyboard? A PIC?
Thanks.
Active8
Hi!
appropriate button.
Thanks.
jameco bgmicro PIC google this group
L
Leon Heller
Chaos said:
Hi!
appropriate button.
You just need an MCU like a small PIC or AVR and a keypad. You scan the
keypad and use software to emulate the PC keyboard, it's quite
straightforward. You should be able to find a few examples with hardware
and sofware with a bit of Googling. I had one of my chaps make one where
I used to work.
Michael Black
Chaos said:
Hi!
appropriate button.
Thanks.
Just open a regular keyboard, and take out the controller. The last one I
stripped even had the electronics separate from the keyboard matrix. Then
add the keys you need, making a nice compact unit that outputs the same
code as a regular keyboard.
Michael
U
Uns Lider
appropriate button.
Drive the columns of your keyboard matrix from the parallel printer port's
outputs and read the rows through the parallel printer port's inputs. I
believe that some of the inputs have pullup resistors, so you might be able
to avoid needing external pullups. And if you're only going to be pressing
one key at a time, you don't need any diodes. Potentially, you could do this
with no components other than the switches and wires to connect them with.
Uhh, except maybe you'd need 4 diodes to keep the column outputs from
frying if someone mashes down a bunch of keys, because I don't think you
have any open-collector outputs to work with?
Alternative approach: Buy one of those numeric keypads that plugs into a
serial port, and relabel the keys.
-- uns
Chaos Master
Michael Black engraved with a +2 athame:
Thanks. I wanted one that would send a keystroke to Winamp (ex. z -> previous
MP3).
G
Gary Tait
Whereas On Wed, 15 Oct 2003 00:07:53 -0300, Chaos Master
Hi!
appropriate button.
Thanks.
For Winamp in particular, I believe you can get a plugin to controll
it from a serial keypad, which you can probably build with a PIC or
such. Salvaging the controller form a PC keyboard is doable, if you
have access to individual keys on your keypad, so you can customize
its matrix to match the original keyboard.
Chaos Master
Gary Tait engraved with a +2 athame:
Someone wrote a plugin for this, because I saw a MP3 player project that used
Winamp + Win 98.
So, I have two options.
