Having an issue with a 4060 timer circuit I'm breadboard-ing. When I apply power the timing starts, and the red led indicates that the oscillator is running as it should because it blinks 'on' and 'off' slowly or quickly according to how the variable resistor is positioned. So I know the chip is good and the circuit is running. However, when I calculate the time it will take for the greed LED to turn on, it never does. I've readjusted the pot over and over after resetting the circuit by disconnecting power. Every time it doesn't light.
Can anybody shed some light on why this might be?
I'd like to get the circuit working. It seems like it should be working.
Thanks in advance!
(Using timer #1)
http://www.zen22142.zen.co.uk/ronj/24h.html
Thanks in advance!
(Using timer #1)
