Hello all,
designing a 5 minute timer (as accurate as possible without using Xtal) but when i divide the clock frequency using 4020, the output at pin 3 increases in time, first 5 minutes the out put is fairly accurate but after 6 thru 45 min the output is increased ,
another words i should get accurate 5 min. blocks, but at 45th minute I get 47 min and 37 seconds. I tried resetting the 4020 with One shot pulse at the end of 5th min. that did not work, any any thing i tried still increases the time at pin 3 of 4020 as time reaches to 45 min range. I appreciate the propogation times of the chip but is there anything i could do to RESET the 4020 to as it was first start up ?
Please see the circuit attached to have a clearer explanation. the circuit is drawn as block diagram to help me to explain.
Thank you for your help before hand
Regards
Regards
