Joel Kolstad
I'm contemplating building a step-up converter from about 3V (it's a lithium
cell and realistically it's almost completely discharged at 3V) to something a
little shy of 15V, where I need 15W plus a few more to cover losses. Starting
with such a low voltage obviously requires some pretty hefty currents, so I'm
thinking that a switcher topology of either a half-forward converter (nice,
simple transformer and low parts count -- peak switch current around 12A) or a
push-pull topology (peak switch currents around 6A, but need a center-tapped
transformer, and controller ICs become quite uncommon given the very low input
voltage since most push-pull applications seem to be in the area of much
higher power). Flybacks or a straight boost converter seem highly undesirable
due to peak currents in the ballpark of 27.5A -- ouch! Since this is battery
powered, I care about efficiency, but I do have plenty of room, so I figured
I'd just use a low (couple hundred kHz) switching frequency and big magnetics
to achieve that end.
Does this sound like a decent strategy?
Also... anyone know of off-the-shelf modules that can perform this job? TI
has one that's close --
http://focus.ti.com/docs/prod/folders/print/ptn04050c.html -- but it's only
12W output power. (It is amazingly small!) This is a low-volume application,
so price isn't a huge concern.
Thanks,
---Joel Kolstad
Thanks,
---Joel Kolstad
