Johann
To all who want to try to repair their broken Modem 3COM US ROBOTICS
56K INT ISA-Slot Type 0613 themselves a tip that may help: I got a
broken one for free, which could be installed as usual with driver
from http://www.driversguide.com.
When trying to connect, it was dialing, but it did not establish a
connection to the server. I found out that the transistor Q7 used for
switching the relay coil of the 5 Volts Fujitsu SY-5-K relay was
broken. I tried out an ordinary general purpose PNP transistor
Motorola 2N4403 instead and it worked. The emitter must be soldered to
the soldering point of the replaced surface mounted transistor, which
is on the side of the ISA-slot, the collector in the mid (connected to
the relay coil) and the base to the one soldering point which is on
the side of the relay.
Good luck,
Johann
Good luck,
Johann
