36 volt charging
Rob
Hi all. I've been blessed (Cursed) with a 36 Volt 3.33 Amp PSW inverter
(2 actually).
I am wondering instead of trying to find a 36 volt charger,
can I use three 12 Volt chargers? One hooked to each battery?
Same type/rating of 12v charger.
TIA ................Rob
W
William P. N. Smith
That will work, though it may not be worthwhile for a 120W inverter...
Rob
William P. N. Smith wrote in 4ax.com:
SNIP
Its 2 400w inverters. Says 3.33 amp on rear panel
W
William P. N. Smith
Oh, it's 3.33 amps output! When you said "36 Volt 3.33 Amp" I thought
you meant input. Depending on your battery bank you might look for a
used golf-cart charger, new ones are mostly 48V, but they all used to
be 36V...
