Jamie Morken
I tested some MOV's, part#: ROV10-560K-S
http://www.mouser.com/Search/ProductDetail.aspx?qs=QV10cN0MjFtgsJoeBrrQMQ==
These are called 35Volt MOV's, and I tested 20 of them with my bench
supply set to 61VDC, and the minimum current was about 10mA, and the max
current was about 50mA, with the vast majority in the 10mA to 20mA
range. With 57VDC across them, none of the MOV's had any noticeable
current through them (less than 1mA indicated on the bench supply).
I would like to use MOV's to protect my electronics, these ones seem
perfect to protect a max 60VDC cap bank. Why are these MOV's rated 35V?
I guess this is an AC rating, so 1.7*35VAC=59.5VDC peak, makes sense I
guess
Is it acceptable (for UL certification) to use these 35V MOV's
to protect a 60VDC cap bank in a battery charger/inverter application?
I was under the impression that MOV's weren't very accurate but these
ones all seem to be pretty close in tolerances.
cheers,
Jamie
guess
cheers,
Jamie
