32-pin PLCC programmer
O
Ozz
ok guys i need to make a 32-pin PLCC programmer.. is it possible????
and no i dont want to pay 100 bucks for one because i cheap ;)
Bill Sloman
Replace the PLCC with an ISP part.
W
Wouter van Ooijen
Of course it is possible, especially if you value your time as
$0.00/hour and are willing to spend $500 in components.
But PLCC32 is a housing, not a particular chip. So exactly what chip
do you want to program? Or do you have a DIP programmer and you want
to make a PLCC adapter?
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
O
Ozz
Wouter van Ooijen
http://www.voti.nl
im looking to program
Amd
AM29F040B
here is a manual i found on it..
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/21445.pdf
oh and the reason i dont want to buy a programmer really is because i
have no use for it but just to program one chip..
i was thinking of maybe using a cheaplpc programmer like the ones used
to program the 32 pin xbox cheap mods but was told by someone it was
not possible.
G
Gary Tait
Whereas On 9 Oct 2003 21:54:17 -0700, [email protected]
(Ozz) scribbled:
, I thus relpy:
Amd
AM29F040B
not possible.
From what it appears, the modchip for the Xbox uses an SST49LF020,
which has the LPC programmability, while the 29F chip is exclusively
parallel program, meaning you will have to make an 8 byte read/write
bus, an up to 19 bit address bus, and the R/W/CE lines for it. Now,
if you could, you could probably get the LPC version of the 29F040.
If you are willing to work and/or spend money, you can build a
programmer.
Another option, if you are savvy enough, is to use a PC or other user
upgradeable Flash appliance (Eg DVD player) and hot switch the roms
at the right point,.
You could also build an adaptor/ wire a socket to use the JTAG on
something that uses that (such as a satellite receiver).
Last resort would be to find a service that programs chips.
Bubba Jones
(Ozz) scribbled:
, I thus relpy:
programmer.
You can build a flash programmer for the AM29F040 for about $50 based
on circuit found at http://www.devrs.com/e/tools.php#toolprgr
Select the link for "2001/07/09 - Frohwein-Sshua Flash Programmer"
Modify the circuit for using a PLCC32 vs. DIP socket
Make sure you use version 1.5 of software if you use 74HC595 chips.
You may need to change BIOS setting in PC to make parallel port
functional for use with programmer.
Bubba
O
Ozz
(Ozz) scribbled:
, I thus relpy:
programmer.
know any good PC programs that i can use to backup and flash a chip?
G
Gary Tait
Whereas On 10 Oct 2003 17:57:41 -0700, [email protected]
(Ozz) scribbled:
, I thus relpy:
Look into the BIOS flash programs for your motherboard manufacturer.
Personally, I have been backing up roms using the BIOS extension
socket on an old MFM HDD card, using Debug, or a Qbasic program (dos
6.22 on a 386 though).
mike
Amd
AM29F040B
not possible.
Advertise for help on a local newsgroup.
Go visit a university electronics lab.
Ham radio club.
Beg for help at a local chip distributor.
You may have to make a PLCC to DIP adapter to use a generic
programmer. You can buy 'em but you don't want to know what they cost.
mike
Bunch of stuff For Sale and Wanted at the link below.
laptops and parts Test Equipment
4in/400Wout ham linear amp.
Honda CB-125S
400cc Dirt Bike 2003 miles $550
Police Scanner, Color LCD overhead projector
Tek 2465 $800, ham radio, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
