32 bit read from AS8S512k32 sram ic
I had a few doubts on this component.
Is there any application note for this IC. What is the recommended de coupling required? Is there any specifiec design/layout requriement? Any precautions to be taken while reading 32 bit data from the device?
Please help
All the technical data and timings you need are imho in the datasheet.
For decoupling use 100nF from Vcc to GND
Thank you,
However, i have noticed that when performing 32 bit data read from this ram using FPGA, occasionally one byte is read as zero. That was why i wondered if there is any precaution to be taken when performing 32 bit read.
Are there any precautions listed in the datasheet?
Are you sure you're not fudging any of the timings?
I note that the datasheet seems to list separate timing for the first and subsequent reads
