I have a 3 Way AC rotary switch - and dont really know how it works.
I need to wire a 3 position AC 240v switch, which will swap between 2 separate power sources, and an off position.
The problem: the 2 power supplies must lead to the same appliance/load, while never both supplying simultaneusly.
All diagrams show the same position switch.
power sources are separate at the "AC IN" side of the switch
I want them combined together at the "AC OUT" side of the switch, so the appliance/load stays the same while the power source can be changed using the switch. The problem: when I combine/connect the terminals at the "AC out" side of the switch, the switch no longer works! current is able to flow in and out of the switch through ALL 4 terminals/poles rather than just 2.
This happens in both my "on" positions, while the "off" position is unafected and works as it should.
If i do not combine the "AC out" terminals, the switch works as it should; only the appopriate 2 poles/terminals allow current through (the first diagram).
This 3rd diagram shows how i expected the switch to work
