3 Phase KVA Calculation Question
F
Fearless Fred
Hi All!
Just want to confirm if my calculations are correct using the following
example:
3 pole mounted 100KVA Transformers connected 3 phase ... is the total KVA
output capacity of this bank of transformers 173KVA??
TIA
Fred
F
Fred
Sorry about that ... will rephrase...
If I have 3 - 100KVA - 4160/480V single phase transformers connected in wye
on the primary and wye on the secondary what is the total KVA capacity of
the bank?
TIA
Fred
F
Fearless Fred
Sorry about that ... I will rephrase ...
If three 100KVA single phase 4160/480V transformers are connected via a wye
connection, what is the approximate total KVA output of the bank?
Fred
Don Kelly
wye on the primary and wye on the secondary what is the total KVA capacity
of the bank?
TIA
Fred
300KVA. If the line to line voltage is 7200V on the HV and 831V on the LV
which is a bit oddball. I assume grounded neutrals on both sides. I would
expect a more common (and technically superior) connection would be
7200Y/480 delta (line to line voltage in each case) -still 300KVA. As long
as each transformer is at rated voltage and current- it's capacity is 300KVA
Don Kelly [email protected]
remove the X to answer
F
Fred
Actually Don the connection I believe is wye-delta 4160/600V. May also be
delta/delta haven't gotten to the pole mounts yet for a look.
Thanks for the feedback.
Fred
wye connection, what is the approximate total KVA output of the bank?
Fred
