2nd try Computer power
K
Kilowatt
I know that is not what I asked but what I should have asked was how much it
cost to keep a computer on per hour. With monitor speaker modem on.
Cubus
0,2 kWh each hour. Less with a LCD-monitor. You have to multiply
with the price the power-station charges one kWh.
bushbadee
See my other post with the B in the subject
I used to leave my two computers (sometimes 3) on 24/7
I found each one was costing me about about $1.50 a day or 45 dollars a
month in my high electric cost area.
26 cents per kilowat .
I cut the cost by going to lcd monitors which cutthe cost by about 20
dollars a month.
Now I have finally started shutting down the computers at night.
That saves at least an additional $40 a month and I do not even turned the
third on which was dedicated to the program to detect alien transmissions,
for got the name.
DarkMatter
You are about as retarded as a Usenet poster can be.
That behavior proves it.
dollars a month.
You are retarded for leaving the monitors on AT ALL when you are not
using the consoles. DOH!
for got the name.
Hahahahaha... My 3 run 24/7 and ALL 3 do SETI units to the tune of
more than 20 a day. The dual CPU unit does 15 a day in pairs.
I am in the 99.819 percentile, and there are only about 9012 ahead
of me, out of 4,819,211 total users.
Looks like you lost out on doing that right too.
The monitors use more than twice what the PCs use. All you had to
do is turn off the monitors, and your bill would have dropped from $40
to $15.
K
Kilowatt
I say you are dead on the mark.
About 10$ a week for a high end computer is a pretty good chunk.
dollars a month.
for got the name.
much
Tzortzakakis Dimitrios
I use the computer 2-3 hours every two days, I get a bill of about 50 euro
each two months.It's about 400 kWh in 4 months.It's about 6,6 cents for the
first 600 kWh.Next ones are more expensive.If you really want to check how
much your computer consumes, turn everything else at home off, and with the
computer running check your energy meter;there should be normally on it
something like:'One kWh is (e.g.)400 revolutions of the disc'Measure how
many seconds does it take the disc to revolute one, and then calculate how
manz times does it revolute in an hour.Then, you will find the
wattage.E.G.it spins 100 in an hour, then it's 250 W.
DarkMatter
Bullshit. I run 3 24/7 and it was four. My bill is not even half 4
times 40.
D.Miller
I believe your computer will not need to be on to use voice over IP
phones. Correct me if I am wrong but my understanding is that phones
will connect to internet thru hardware connected to your cable modem.
Only your cable modem will need to be running.
D. Miller
dvm001atrochester.rr.com
Gerald Newton said:
much
I think I get your point. If the Internet is going to be used for
telephones the power comapny is going to be making a bundle or maybe there
will be another power crunch.
